viessmann wb1b-35 gas smell in cabinet
pumbaa
Member Posts: 8
in Gas Heating
its an internal leak after shut down. there isn't a leak in the gas train up to the gas valve0
just curious but what is tech support saying?
call a rep. last one that they had boiler replied and 2 weeks later the same problem with new boiler
sorry that should say replaced
thinking may be problem with venting???0
A gas leak is a gas leak. It is also an explosion waiting to happen. I don't want to read about you in the papers. Or on the 'net.
If you insist on living very dangerously, at least do your neighbours a favour and get the gas shut off to your house at the service entrance.Br. Jamie, osb
I had a bad gas valve years ago on a wb1a, was kicking out an odor. Glad you’re all set0
@pumbaa Hi there, yes years later, but I’m having the same thing at a customers house and im just wondering what you ended up doing? Just change the board or the gas valve as well? It’s almost 8pm here on a Friday so I can’t get tech support..0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
