Do mod cons need firecode 5/8 sheetrock on ceiling and walls?
D107
D107 Member Posts: 1,944
I'd heard that due to the sealed combustion or whatever that mod cons are not required to have the 5/8 sheetrock above and around them in boiler room. I happen to have two 1/2inch sheets lying around and depending on what I get installed I'd love not to have lug two more 5/8" in. This is New York State.
  • JUGHNE
    JUGHNE Member Posts: 11,513
    Do you have or have to have a boiler room?
    Sometimes these things just sit in an open basement.
    D107
    Jamie Hall Member Posts: 26,830
    Depends on clearances and a few other things. Best thing to do is to talk to the authority having jurisdiction -- building inspector, fire marshal -- and see what they say. Were it I, I'd say that anything within three feet needed to be fire rated 5/8 sheetrock; depending on the layout I might even go so far as to say the whole boiler room needed to be fire rated. I'd have to look. But then I was known as a rather conservative type... talk to your people.
    D107
  • D107
    Thanks. This won't be open basement; bottom line for me better to err on the side of safety....Expense is relatively minimal.
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,584
    Yes
