Help Please! Determine boiler age
RayWohlfarth
RayWohlfarth Member Posts: 1,785
Greetings,
I am writing a new book and was hoping to include a list of ways to determine the age of a boiler. I was hoping you could share with me any secrets you have for doing that such as a secret formula, decoder ring, or looking at the serial with squinted eyes. I will be eternally grateful for your input.
Ray
Ray Wohlfarth
Boiler Lessons
  • Old serial number plates are hard to read. Wiping down, and rubbing pencil lead over it can make it easier to read.
    Really though, should one ever question a lady about her age?—NBC
    Erin Holohan HaskellCanucker
  • RayWohlfarth
    Nicholas, LOL Ever the Gentleman. Thanks
    Ray Wohlfarth
    Boiler Lessons
  • ratio
    ratio Member Posts: 4,053
    Count the rings? :wink:
    & another trick with nameplates is a pic with your phone. Both with & without the flash, from several angles. Sometimes you can zoom in & see impressions or surface differences left by the old text. I like to send pics of model/serial #'s to the office when I order parts, that way I don't get blamed for a wrong number!
  • Good idea, and the camera can be held at angles not achievable by 72 year old knees!—NBC
    hot_rod Member Posts: 25,307
    sometimes the components on the boiler or system can help, gas valve, circulators, etc. Most manufacturers build a date into the serial number, it could be coded or as simple as week and year like Grunfos has used.
    unclejohn
  • RayWohlfarth
    Thanks for the info everyone I will let you know if I come across something to help
    Ray Wohlfarth
    Boiler Lessons
  • JUGHNE
    JUGHNE Member Posts: 11,452
    I drag a grandson around to take pictures. He can get down easier, has a better camera phone and just e-mails the pictures to me so I can see them on the big screen. ;)
    For dating things, we got NG here in 1967, that is one benchmark.
    If something looks converted from LP to NG, then that benchmark is out.
    I also look for evidence of a coal room, coal shoot, oil lines and maybe buried oil tank...vents & fill. Footprints of old equipment on the floor can tell stories.
    Asbestos insulation and/or painted pipe might reveal original parts or those from later changes.
    Canucker
  • RayWohlfarth
    You sound like Sherlock Holmes JUGHNE
    Ray Wohlfarth
    Boiler Lessons
  • ratio
    Sherlock Holmes had it easy. He chased dishonest crooks. We have, additionally and in no particular order: the clueless, the know-it-alls, the know-you're-the-crooks, and engineers. :)
    JUGHNE
  • RayWohlfarth
    Ratio thanks for the Sunday chuckle
    Ray Wohlfarth
    Boiler Lessons
  • Gilmorrie
    Gilmorrie Member Posts: 196
    With residential boilers, I'm not sure how much age matters. I suspect that many boilers are replaced, before necessary, due to sales pressure. My hot-water boiler is 60+ years old, based on when it was originally installed. It has been well maintained, and runs fine.
  • Paul48
    Paul48 Member Posts: 4,469
    @ratio
    Sometimes you follow the dishonest crooks. :smile:
    ratio
