Fujitsu indoor coil replacement
charliechicago
Member Posts: 188
Hello to all,
I have a fujitsu air handler coil that has a leak and I am replacing it under warranty. I am trying to find a video or literature that could walk me through the process before I do the job but have not found anything. I contacted fujitsu but all they had was some info on how to remove the blower. Anyone have info?
Thanks, Charlie.
Thanks, Charlie.
Did the system ever run in a vacuum when low on charge?
Is there a chance that air could have been sucked into the system thru the leak?
There probably is a low pressure switch to shut down?
Is it a single inside coil or multi unit?0 -
Thanks for getting back.
It never ran in a vacuum.
It’s a single. One ton.0 -
IIWM, and I was certain that the charge was never contaminated, I guess I would just pump it down.
Disconnect unit, assuming flare fittings.
Hang and connect new.
Then just like original installation.
I do not use quick connections for testing or evac.
I pressure with 300 to 500 PSI of dry N2.
Triple evac with N2 flush each time.
On the last evac with good micron holding.
I crack open and then close the small line to pressurize the system slightly then use the quick connect fittings after that.
With the existing lineset I have found it requires more vac pump time because of oil in the lines.0 -
I think the OP wants to replace just the indoor coil? Not a job I'd want, especially warranty if it didn't include labor to as well. Any reason they won't just replace the head? I don't think any of our suppliers would do that to us.0
I was assuming the complete head. Not just the copper coil.
I would fight to get the complete head if under warranty.
I have had complete Sanyo/Panasonic outdoor units furnished for a compressor failure under warranty. I would remind them that there are other good brand name mini's for future use by you.
Almost pay some out of pocket to avoid the unpaid labor.
(I have done this losing money, but time is worth something)0 -
Change the whole unit. You'don't be taken apart the entire unit. Easier, quicker, and no worries about missING a wire connection.0
Thanks for the answers.
I’m sorry it wasn’t clear, I am only replacing the coil. My Supply house, who I have a good relationship with said Fujitsu will only supply the coil. Is that something I should fight with Fujitsu about or the Supply house? Anyway, they said the air handler is already obsolete so I have no choice but to replace the coil.
Thanks, Charlie.0 -
How old is it? Odd that it's both a warranty replacement and obsolete equipment.
If you know the guys at the supply house aren't just telling you that Fujitsu will only supply the coil, maybe you can talk direct to the Fujitsu rep. If it's something that they feel should be warranted even after the unit is obsolete, maybe they have support docs/videos to go with it.
Fujitsu will only replace entire unit if it fails within the 1st year. After that they will only replace the coil.0
How old is the system?
I'm just curious now, I really don't have much else to offer re changing out the coil, sorry. Go slow, take pictures, don't loose the screws!
I hate it when these manufacturers do this to us. It makes us ( contractors) look bad, and usually dips hard into our time and out of pocket expense. Good luck guess I will be thinking twice about them.0
Thanks everyone.
Dennis, I’m with you.
Ratio, it’s only three years old. You are right! So slow and take pictures.
Radmix, and anyone else, are other manufacturers better with this type of thing. I really like fugitsu and my local Supply house sells them but it other manufactures have a better warranty I would at least look into it.
Thanks, Charlie.0 -
I would go to the owner/manager of your vendor and have him bring your local Fujitsu Rep and Fujitsu Regioinal Manager into the conversation. Your Supply House should be on your side in this and should fight for you. That unit is defective, deficient, etc and should be replaced. You are upside down on this job all ready having to even replace the evap complete. If they are not paying your labor I would demand support from them for a full replacement. The Rep can make this disappear. It won't be easy for him, but you bought the unit in good faith. You shouldn't get buried on this. Oh, tell them that the customer demands a full evap replacement, and they should.1
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
