Flaring tools
Jack
Member Posts: 1,049
I have had a couple instances on 410A where the 1/4” die on my Yellow Jacket 60278 slips...with predictable results. Disappointing as when it is right it leaves beautiful flares. It doesn’t hold the 1/4” tubing securely, pushing it back as you run the die in. YJ does not sell parts for this tool. What is a good 410A flaring tool?
I've had great luck with a brand called Anchor, United carries them. Super cheap compared to Ritchie, but very good quality, eccentric cone with roller bearings. I can't recall if they go down to ¼ though, sorry.0
Have you cleaned the die in the clamping block?
The blocks that I have are grooved to grip the tubing and if dirty would slip.0 -
@Big Ed I've had excellent results with the same one. Best one I've used to date.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
I have the same problem with my YJ tool on 1/4 inch. I have had good luck with the Spin Flare.
flaringspin.com/
Also , United Refrigeration sells a Daikin Flare Gauge for like 8 bucks ( a plastic one ). They make an aluminium one but I have not had any luck locating a source for these by themselves.hvacfreak
Mechanical Enthusiast
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV'sEasyio FG20 Controller
I just received a Hilmor Orbital Flaring tool. Pretty slick and you do not need three hands. It is identical to the Imperial kit shown in Big Ed's post, but did not come in a nice case. My daughters 15 yr old furnace gave out and I'm putting in a triple head Fujitsu today and tomorrow. Yesterday, working alone, I pulled all the crap ductwork out as well as plenums, furnace and venting. At 69 in a dirt crawl space for a couple days I am thinking about my daughter..."How do I love thee? Let me count the ways!"0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
