Are These Pipes Covered With Asbestos?
Joseph_4
Member Posts: 320
Hi.
Can anyone tell me if these pipes are covered in asbestos?
Thanks
Joe
HHI Services LLC
Thanks
Joe
HHI Services LLC
Yes, that is a asbestos treated cardboard insulation. I have it on my steam mains also. You can encapsulate it or have it removed. Mine are painted and I just leave it be.0
You can get bags to encapsulate. The trick is to wet everything. All elbows are high grade asbestos. Also wet them and put them in plastic bags.0
Thanks to all for your comments.. greatly appreciated!
Joe0 -
Better off leaving it , you will never install new insulation on them pipes
could always doctor it up with Childers mastic and cheese cloth.gwgillplumbingandheating.com
I've used -- with great success -- the plaster impregnated gauze bandages doctor's use to make casts. Come in rolls of various widths. Cut off a manageable length, get it nice and wet, wrap it around the stuff making several layers -- when it dries, presto your asbestos is safe and encapsulated.Br. Jamie, osb
I believe they call that insulation "aircell" and it does contain asbestos. The fittings are also covered with material likely containing asbestos0
It looks like it is, but the ONLY foolproof way is to have it tested. I know people are going to do what they want, but unless you have training and use the correct respirator, abatement materials and techniques, you really shouldn't be touching it all. Asbestos abatement is no longer exorbitant as it was 25-30 yrs ago. It's pretty affordable. Asbestos exposure has a long latency period to illness and just because your not hacking or choking when your disturbing it NOW, don't be fooled. Its always an issue when house is sold. Get an abatement contractor and get an air sample before & after. Mad Dog1
On the other hand, if it's there you can use that to reduce your real estate tax assessment...mxfrank said:Asbestos pipe insulation can become a problem if you sell the property. To protect your investment, a documented abatement is your best bet.
@Jamie Hall not ever place does that, actually most areas I am familiar with don't. The house assessment is based on square footage and location, that's about it. My township has no clue what's in my house.
For all they know the house is made out of asbestos, wouldn't make a difference.0
- 116 Geothermal
- 15.8K Strictly Steam
