Homer repiped his copper near boiler piping to black steel
Kahooli
Member Posts: 112
Posting to show the work I've done over the past few months on night and weekends. I tried to follow the work of the pros here as well as I could, and added few things that made sense to me as well.
I have previously posted some pictures of my system when I acquired it and after insulating the header here:
https://forum.heatinghelp.com/discussion/159422/my-new-to-me-steam-system#latest
I'll add pictures to the Repiping folder later tonight (I need to take them first!).
https://drive.google.com/drive/u/0/folders/0B4UzDZ2eO6gKSWV0VHpnT0FrM1U
The risers are 2-1/2"x36" dropping into a 3" header. The main takeoffs are 2-1/2" then reduced to 2" to connect to the mains. The equalizer and wet return is 2" as well. The dry to wet returns are 1-1/2".
The wet return goes through a 2" wye strainer before dropping into low point "sediment trap" with a plug in the side. Mud leg has a reducing el and a 2" ball valve drain.
I added a raised steam syphon for the controls (albeit I don't like how it turned out overall and may change it next year) and added a vaporstat and a second -30-0-50" w.c. low pressure gauge.
I bought about half my fittings old stock on ebay for far less than list price, and bought the rest of the pipe and fittings from the local pipe supply house or when they were not an option, from supplyhouse.com or zoro.com. I got all the valves from Amazon as they routinely discount their last few inventory to 85% off list price.
I'd love to hear comments / criticism. I am an EE by day, so this was all very new to me. I'm sure I made some things harder than they needed to be, and wasted a few fittings where I could have simplified it. And some of it looks a bit ugly.
I still need to add a few more pipe supports and then re-insulate the new pipes. I will update when that's done as well.
As a homeowner in a similar position, thanks for posting an update with your progress. Mine is a copper-piped, no main-vent mess. I'm looking forward to seeing your repiping pictures.0
Looking forward to the pics. Btw, who do you use in Cinci for maintenance and service calls? I'm in Cinci too.0
I've only been in the house about a year, so no service calls yet. Pics added. Sorry about the weird lines in the pictures. I have no idea what is wrong with my phone camera. Ill take some with a real camera if anyone really wants.
https://drive.google.com/open?id=1_EGMZCnGtIsL1hlDCkQchUwUsum5FVph0 -
Pics aren't showing up...0
no comments at all? Hmm. ah well. heats fine after some skimming.0
Great job, you should have the driest steam in town.
3PSI gauge0 -
Looks great!! I especially love flange connection on the header. This will make it easier to service the main or repipe when new boiler is needed. Very very nice!!0
some valves you got there0
Looking good, but you don’t need that pig tail on your water trap, the water trap itself takes care of that.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Surprisingly they were all pretty cheap.SeanBeans said:some valves you got there
Like the valve on the wet return
https://www.amazon.com/gp/product/B00835U4IC/ref=oh_aui_detailpage_o01_s04?ie=UTF8&psc=1
If you wait till they get down to the last 1 or two in stock the price dropped to $22
I did have a couple that were duds and had to be returned. But for my long, drawn out project it was worth the hassle.
I made some pipe stanchions from a 1/2" pipe, 1/2" floor flange, 1/2" x X" bolt, three nuts, a washer and a cast pipe support.
http://www.supplyhouse.com/Empire-Industries-41HB0250-2-1-2-Black-Split-Ring-Extension-Hanger
Not that those stanchions aren’t cool, but why didn’t you just use rod plate to the ground? Just, because?0
All thread was really bendy for the tall one, so I went for a stiffer option.0
nice clean job. Only thing I notice and not positive due to the picture. where you enter the wye should be a close or shoulder nipple only. Looks like a 3" nipple..0
You're correct it's not a close nipple. I'm of the opinion that by using a wye and not a tee that that requirement is removed - the reason the tee and 90 elbow requires a close nipple is satisfied just by using the wye.lchmb said:nice clean job. Only thing I notice and not positive due to the picture. where you enter the wye should be a close or shoulder nipple only. Looks like a 3" nipple..
4
- 120 Geothermal
