Goodman furnace
danitheplumber
Member Posts: 98
in Gas Heating
Goodman furnace no heat everything works except gas. The gas regulator has a wire harness to it. I unplugged it and replugges it and gas came through giving heat. I assume wire came loose. Anyone seen this or kbow why this would happen? Thanks appreciate it stay warm
Loose Stakons or Molex connectors occasionally don't make contact good enough to allow operation. Often just unplugging & plugging back in will clean them & allow operation until the next time it happens.0
- 15.8K Strictly Steam
