Goodman furnace
Goodman furnace no heat everything works except gas. The gas regulator has a wire harness to it. I unplugged it and replugges it and gas came through giving heat. I assume wire came loose. Anyone seen this or kbow why this would happen? Thanks appreciate it stay warm
  • ratio
    ratio Member Posts: 4,264
    Loose Stakons or Molex connectors occasionally don't make contact good enough to allow operation. Often just unplugging & plugging back in will clean them & allow operation until the next time it happens.
  • JUGHNE
    JUGHNE Member Posts: 11,604
    By gas regulator do you mean the gas valve inside the furnace?
    (which does have a regulator inside it BTW)
    danitheplumber
