Hellish apartment!
paulqu
Member Posts: 1
My apartment is too hot, can't even sleep when it's 30 outside!
Seems like the whole apartment has only one (very long!!) radiator that goes from the bedroom to the living room...
Not quiet sure if this is a 1-pipe system or 2-pipe.. There a valve that says "Hoffman Specialty", which I think is a Hoffman 508. It has an automatic and a manual setting (not quiet sure what this is). Photos included.
Any idea how I can regulate the heat? Or at least be able to turn it off when I need to?
Hot water single zone, based on the soldered copper and bleed caps. No thermostat in your unit I'm guessing? Any valves at the beginning of the radiator?
Ive seen buildings like this and tenant was able to throttle the water going through their unit.
If you dont have valves and building staff isnt helpful try putting blankets or cardboard over part of the radiator (s) to reduce heat output. Not pretty but it works.1 -
Have you looked under all the panels on the baseboard heater?
I requires 2 pipes to it, maybe the other end has a valve?0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
