Hartford Loop on 1 pipe systems?
jgach11886
Member Posts: 13
I was curious if the hartford loop is also on 1 pipe steam systems? I have a lot to learn about piping steam systems, I understand the point of the drop header, and that returns need to be pitched, but I believe the 2 pipe systems are the ones that have piping going around the exterior of the basement pitched back to the boiler, and those make sense to me to have a hartford loop? Just curiuous if its only on 2 pipe or also on 1 pipe?
thx
thx
A parallel flow system will have the Hartford loop, 1 pipe 2 pipe doesn't matter.
On a counter flow they can be put in, but to my knowledge aren't necessary due to the lack of wet returns being able to drain down the boiler.2 -
Here's a good steam primer:
http://www.peerlessboilers.com/DesktopModules/Bring2mind/DMX/Download.aspx?EntryId=140&PortalId=0&DownloadMethod=attachmentBob Boan
You can choose to do what you want, but you cannot choose the consequences.-1 -
One pipe or two pipe is determined by the number of pipe connections to the radiators......not the boiler. The piping around the boiler is in general the same for both systems0
I believe your other post you stated you work for a service company.
You would like Dan's book "The Lost Art of Steam Heating-revisited"
Great read, makes learning a lot very easy. If you have any interest in the subject, it is a hard book to put down. IMO0
