Best pipe sealant for boiler work? Rectorseal or Gasolia
cwilliams2000
Member Posts: 140
I am not a pro but do work at home and the cost of this really isn't a big deal. I have used rectorseal often with no issues but for boiler work or even cold water work is gasoila a better choice?
Everyone has a favorite and their is no right or wrong. Whatever works for you.
You just have to make sure whatever dope you use is compatible with the system your working on.
Some products can't be used on plastic pipe. Some can't be used with propane gas.....just have to read the label.
That being said I like Rectorseal TRUE BLUE. It works on pretty much everything. I use it over Teflon tape (regular I don't like blue monster) usually (except on oil burner lines).
The only thing I don't like is it sucks getting it off your hands!!
Got some in my hair and it wouldn't come out till I got a haircut.0 -
On 4” fittings and larger it’s old school Lamp Wick and Blue Block. On everything up to 3” I use Blue Monster Tape and Megaloc dope. Never had a leak!!...DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
monster works on everything, gas ,oil, water"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
