Ok to trim the bottom tab on a taco hy-vent?
Leon82
Member Posts: 684
It looks like it just stops it from traveling upwards into the body.
And why would you need to trim it?0
I was good g to put it into a 1/8 ball valve and am worried it will bottom on the ball0
I don't think Taco made it that long just to get rid of some extra brass.Bob Boan
Shouldn't be a problem with trimming, however another option that we started last making last year is a 1/8" check valve instead.
When using you take the stem out of the vent.
Dave H.Dave Holdorf
Taco, Inc
1
- 167 Indoor-Air Quality
