Pex runs in basement
noodles555
Member Posts: 6
The basement is a heated space and I have pex al pex running up to feed cast iron radiators my question is should I space the pex at certain spacing and if I have flow and return close together will one transfer heat to the other and lastly is it a good idea to insulate the pex?
Hello, Plastics emit radiant heat about nine times better than new copper. Insulate!
Yours, Larry0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 106 Geothermal
- 982 Plumbing
- 389 Solar
