PEX tubing - snap rings
Snowmelt
Snowmelt Member Posts: 1,428
Have a new customer that has his heating system with a majority of PEX tubing in the walls, Once a year for 5 years he had a PEX ring split in half, it wasn't winter but not freezing temps, It was a zern product and the house is under 10 years old. he wants to replace all the rings, I am a viega guy with the S. S. sleeves. I am trying to convince him to go all copper. or take the pex out and change it to viega heating pex. what would you guys do?
  • Ironman
    Ironman Member Posts: 7,730
    One type of the pinch rings was known for this. I believe it was the Zurn brand.
    If it's O2 barrier pex, then I would not replace it since the rings are the issue, not the tubing.
    If it's Type A pex, you can use expansion fittings like Rehau's. They're the best and strongest pex fitting, but you'll need their tool.
    Bob Boan
    hot_rod Member Posts: 25,357
    At the PHCC show last week Zurn was showing expansion fittings, I didn’t think they were an A Pex?
    I like the stainless collars best, good hold and professional looking
  • Ironman
    I'm not familiar with what Zurn's new offering is. Roth told me that their orange PERT tubing was compatible with cold expansion fittings like Rehau's. I tried a Rehau coupling on it a couple of years ago and it seems to have worked fine.
    Bob Boan
