PEX tubing - snap rings
Snowmelt
Have a new customer that has his heating system with a majority of PEX tubing in the walls, Once a year for 5 years he had a PEX ring split in half, it wasn't winter but not freezing temps, It was a zern product and the house is under 10 years old. he wants to replace all the rings, I am a viega guy with the S. S. sleeves. I am trying to convince him to go all copper. or take the pex out and change it to viega heating pex. what would you guys do?
One type of the pinch rings was known for this. I believe it was the Zurn brand.
If it's O2 barrier pex, then I would not replace it since the rings are the issue, not the tubing.
If it's Type A pex, you can use expansion fittings like Rehau's. They're the best and strongest pex fitting, but you'll need their tool.Bob Boan
At the PHCC show last week Zurn was showing expansion fittings, I didn’t think they were an A Pex?
I like the stainless collars best, good hold and professional lookingBob "hot rod" Rohr
Living the hydronic dream0 -
I'm not familiar with what Zurn's new offering is. Roth told me that their orange PERT tubing was compatible with cold expansion fittings like Rehau's. I tried a Rehau coupling on it a couple of years ago and it seems to have worked fine.hot rod said:> @Ironman said:
Bob Boan
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
