Over Kill, in a good way.
AMservices
Member Posts: 611
A family member of mine needed 2 steam boil is replaced. You can imagine how happy I was.
converting from oil to gas. One boiler was original to the house (A dilapidated Snowman) and the other had a 50's look. "Pacemaker" was on the cover.
I installed 2 weil-maclin EG-30. I know the 3" drop header is over kill and making the pressuretrol water seal out of brass was unnecessary, but it's for the family and it looks Awesome!
2
Wow, Looks beautiful!0
Beautiful. Just....beautiful.All Steamed Up, Inc.
Consulting0 -
Nice Job!!
Poor old snowman, still had it's stack switch!! The old Beckett has probably been their since the 70s.
Don't know who made the Pacemaker0 -
I only know of one Pacemaker in my area...very quiet boiler with a 1725 burner on it. Beautiful job on the boilers.. have to love steam pipes..
Looks nice. I'm a bit surprised you would use hollow concrete blocks turned on their side.
It's not overkill. And you're right: It looks awesome!New England SteamWorks
newenglandsteamworks.com0 -
Admittedly, if i have an achilles heal in my work its the electrical, its always sloppy. I LOVE the way you do yours. I wish I wasn't always in a "gotta get to the next one" mindset and was able to slow down and do it just like that.
Nice jobTom
Montpelier Vt0 -
I’m smiling. Well done!Retired and loving it.0
beautiful installationASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Lucky.lchmb said:actually just had a customer ask about doing a new construction in steam...
When I get that chance, I'll be asking @gerry gill For pointers on designing a mini tube boiler and then use @izhadano vacuum boost system to overcome the pressure drop using smaller piping.
Good luck, I hope you get the job.0 -
Great install! I am not sure your family knows how lucky they are.
On the subject of snowmen boilers, I had a down fired steam snowman in one of my homes. Between the size of the home, the small crack in the boiler talk about lack of fuel efficiency.:NYplumber:0 -
Beautiful installations. Really fun to go over the details in the polished/painted pipes and fittings. It wouldn't pass in my area due to the hollow blocks and 15 PSI gauge but NY/NJ is annoying like that. I like the pressuretrol setup.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0
