Foreign objects
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,684
Just for fun, what unexpected things have you found inside heating systems?
Retired and loving it.
«1
  • newagedawn
    newagedawn Member Posts: 586
    in the 80's found birds, squirrels, not to much anymore i think they are getting smarter to carbon monoxide,lol
    "The bitter taste of a poor install lasts far longer than the JOY of the lowest price"
  • Ironman
    Ironman Member Posts: 7,851
    edited October 2017
    A roofing nail. Found it in the inlet flange of a series 100 circulator.
    Several companies/techs had gone out to the job, but could not fix the problem which was no flow because the nail was acting like a check installed backwards. They bled air, changed out the circ, you name it.
    The circ was on a vertical return at the boiler. The nail would allow water to pass backward up the return, but not down into the pump. Gravity would cause it to drop and close off flow.
    Bob Boan
    BobC
  • Henry
    Henry Member Posts: 998
    We were replacing some valves in a large commercial complex downtown. We found the key stuck in a butterfly valve and a tool kit on the outlet of a pump. It was 8 inch piping. The tools have been there since 1985!
    RoohollahRomanGK_26986764589
  • DanHolohan
    Good one, Henry!
  • STEVEusaPA
    The usual critters, but once a baby owl, alive, in a cold start boiler flue pipe. The owner jammed the barometric damper shut because he thought it was a squirrel. He called me. I called animal control.
    They got the baby owl out alive, and told us they take them far out into the country and release them (I hope they did).
    I also found a melted screwdriver in a cleanout box.
  • DanHolohan
    That's a real hoot, Steve! ;-)
    STEVEusaPAMilanD
  • KC_Jones
    KC_Jones Member Posts: 5,907
    No pictures, but in one of our environmental test labs they found a lacrosse ball inside the piping for one of the pumps. This is inside our plant and we do all the work, no one has a clue how it got there. They found it when someone said "hey what is that weird noise coming from the pump?".
    2014 Weil Mclain EG-40
  • STEVEusaPA
    lol....I wouldn't use that one at open mic night...
  • DanHolohan
    Tip your waitstaff!
  • DanHolohan
    KC, I once found a pair of welding gloves inside a shell-and-tube heat exchanger. They were up against the tube sheep with fingers splayed.
  • rick in Alaska
    rick in Alaska Member Posts: 1,513
    Dead seagull at the bottom of a chimney that had no cap, a bat inside the blast tube of an afg, ( still not sure how he got there), the bolt package for a Buderus g115 inside the firebox.
    The one I still need to get to is across the bay that I did a tuneup on. I was running late and they were holding the plane for me, and I could not find my Leatherman multitool. I had to leave without it, but I suspect it got dropped inside the top of the flue collector hood, and I didn't see it. I miss that tool.
    Rick
  • Harvey Ramer
    Harvey Ramer Member Posts: 2,281
    Slightly off topic, but I found a stinkbug in a watertight receptacle box once. That is still screwing with my head.
  • DanHolohan
    Rick, I like to think someone will post here in 20 years to say they found your Leatherman someplace cool.
    rick in AlaskaRomanGK_26986764589
  • DanHolohan
    Harvey, that’s just magic.
  • bob_46
    bob_46 Member Posts: 813
    Empty caulking tube folded in half jammed up against a 2 1/2 " butterfly valve, fortunately it was Vic pipe. 14" wye strainer high press. steam a pair of carharts and a steel lunch box and some 1 1/8 nuts. A deflated basketball in a 8x4" bell reducer on a pump inlet.
  • DanHolohan
    Gosh, Bob.
  • STEVEusaPA
    Not one Santa Clause sighting?
  • DanHolohan
    The night is young.
  • KC_Jones
    Those dumb things go everywhere, it's truly amazing.
    RomanGK_26986764589
    EBEBRATT-Ed Member Posts: 19,497
    An electrocuted mouse inside an electrical panel that was missing a knockout plug.
    A dead squirrel inside a gas water heater 4" flue pipe.
    Took a semi hermetic ac compressor apart to have the windings rewound and found that a cold chisel had been left inside the motor housing.
  • DanHolohan
    Ed, what can I say? :-)
  • SeanBeans
    SeanBeans Member Posts: 525
    Not me, but a co-worker and my old install manager tore out an evaporator coil and found about 300 bucks stuck in the A-Coil.. it was almost rotted out fully but they went to the bank and split it.
  • This was in a crawlspace, not a heating system; many years ago.
    A rat - minding his own business, walking along a copper water service to get home after a long, hard day in the sewer. He confronts a wire in his path; gets annoyed and chews some of the insulation off and then hops over the wire to continue home. His belly on the bare copper wire and his paws on the bare copper water service completes the circuit and his life becomes complete; a beginning and now, an end.
    RomanGK_26986764589
  • DanHolohan
    Sean, that is inspirational. Alan, that is poetry. Thanks, guys!
  • jhatcher
    jhatcher Member Posts: 3
    Baby possum in the electric heater of an air handler. Quite the aroma.
  • DanHolohan
    Well-done?
  • ratio
    ratio Member Posts: 4,176
    A skinless treerat poped out of the down spout discharge at my house a few years back. Apparently he thought he could make it through & got stuck some time before the rain. I can only guess at what happened, but the results were startling.
  • DanHolohan
    I’ve never heard of a skinless tree rat. Learning every day!
  • lchmb
    lchmb Member Posts: 2,997
    Had an older customer, the husband passed in the spring. She called and asked me to take care of the furnace prior to winter.. When I pulled the front jacket (Thermopride) I noticed a box tucked in the bottom left. When I opened it, I found a big wad of money. I took it upstairs and made someone's month. She was having a hard time covering things and this made it much easier for her...
    ChrisJBobChydro_newbieRomanGK_26986764589
  • DanHolohan
    I love this story. Thanks.
  • I was dispatched to replace a Lennox Pulse heat exchanger in the basement of a home on a cool fall morning. The furnace had been running and maintaining temp in the home. I fired it up when I arrived. After disassembly, and the initial hoist to remove the heat exchanger from the cabinet, a full grown live green snake slithered out of the secondary and started off across the floor at high speed!
    I was shocked and didn't want to be responsible for releasing a snake into this family's home. I wasn't sure what to do, so I quickly grabbed a hammer and bopped it on the head in an attempt to stun the animal.
    It was then that I learned that snakes bleed profusely from the head and I had an entirely new problem on my hands.
    Solid_Fuel_ManRomanGK_26986764589
  • DanHolohan
    Some days just can’t win.
  • Lance
    Lance Member Posts: 328
    I found a mouse in a furnace blower wheel. He must have thought he found the best exercise wheel ever until the motor kicked in and centrifugal force did the rest. I also found an Amprobe under a blower wheel in a furnace. In a 6 inch air duct I found some workers bagged lunch over 20 years old. Never touched. Probably a prank forgotten.
    I found a connecting bolt rod in a sectional steam boiler header from the factory. I'd have sent it back but this was my third boiler into the basement, as the other two had pinholes in the castings. Go figure! At least this one did not leak.
  • DanHolohan
    Great stories, Lance, especially the lunch!
  • j a_2
    j a_2 Member Posts: 1,804
    I found the guy that installed a beautiful steam boiler and made a disaster out of it to be a foreign object,causing much foreign object damage
  • Alan Welch
    Alan Welch Member Posts: 271
    Not unexpected but went on a call where a squirrel had died somewhere in the ductwork, smelled pretty bad. Found it pretty quickly in the "squirell cage" of the furnace.Guess that"s how it got its name. Also tin knocking hammer, tin snips in ductwork.
  • ChrisJ
    ChrisJ Member Posts: 17,060
    edited October 2017
    Hmmm
    Ichmb, check your PMs.
  • DanHolohan
    Great stuff, guys. You're making my week.
  • Ironman
    Back in the late 80's, we installed several Lennox Pulse furnaces in a new funeral home. My guys thought that one them must have been haunted because it would initially fire right off but then instantly shut down. For those familiar with the Pulse, you know it has a draft inducer that basically purges the HX's and proves the draft. Once ignition takes place, the inducer isn't necessary and shuts off. My guys had tried replacing the inducer, pressure switch, etc. Nothing fixed it.
    I must have watched it for 30 min to an hour when I figured there had to be some form of restriction in the venting. I pulled the intake pipe off of the furnace and found a golf ball laying there at the inlet. It left space around it to prove the pressure switch, but not enough to allow adequate air once the combustion cycle started.
    Someone had to have shoved the ball in from the pipe outside and it rolled all the way down to the furnace through several turns. :#
    Bob Boan
  • DanHolohan
    edited October 2017
    Bob, maybe a hole in one? HAHAHAHAHA!
    You guys are killing me!
    Ironman
