Insulate my loop seal?
CKNJ
CKNJ Member Posts: 65
Quick question about my recently replaced loop seal. Single Pipe system with dry return. I have insulated both the supplies and the return. But, should I insulate the loop seal as well or leave it bare?
    EBEBRATT-Ed Member Posts: 19,755
    up to you. It's going to be full of water all the time so insulation probably won't save much fuel....but every little bit helps
  • jumper
    jumper Member Posts: 2,504
    plus hot water is better than cold
  • The Steam Whisperer
    The Steam Whisperer Member Posts: 1,313
    The water in the loop seal will get up to 212 F or so and will cool down very slowly, so it is giving off heat alot longer than a steam line. I have used the condensate return off steam pipes to help heat basements, so I'd insulate it.
