Insulate my loop seal?
CKNJ
Member Posts: 65
Quick question about my recently replaced loop seal. Single Pipe system with dry return. I have insulated both the supplies and the return. But, should I insulate the loop seal as well or leave it bare?
up to you. It's going to be full of water all the time so insulation probably won't save much fuel....but every little bit helps0
plus hot water is better than coldEBEBRATT-Ed said:up to you. It's going to be full of water all the time so insulation probably won't save much fuel....but every little bit helps
The water in the loop seal will get up to 212 F or so and will cool down very slowly, so it is giving off heat alot longer than a steam line. I have used the condensate return off steam pipes to help heat basements, so I'd insulate it.To learn more about this professional, click here to visit their ad in Find A Contractor.0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
