Looking for a small hydronic fan coil unit
RayWohlfarth
Member Posts: 1,987
I want to replace a small hydronic fan coil which is only 35" wide 9 3/8' deep, 25" high 200 CFM
I cannot find one less than 40" wide. The wall encasing this unit will not allow a wider unit. Its 110 volt
I would be eternally grateful for any suggestions.
Thank you in advance.
Ray
Ray
Ray Wohlfarth
Boiler Lessons
Boiler Lessons
Did you look at the Aircell product from spacepac?
Try Magic-Aire0
Are you looking for a PTAC type, or just the coil? Did you try Aquecoil if just the coil?0
Harvey Thanks They want a replacemet for the existing.
Dan Foley thanks I will check it out
HVAC nut it will use hot or chilled water and a fan
I apperciate it all
Ray Wohlfarth
Boiler Lessons0 -
Did you try First Company?
They have hydro air units for many applications.0 -
as @Dan Foley said Magic Air is worth a try0
Multi Aqua is another option to look at.Bob Boan
What about a kick space heater, they come in wall mount cabinet style.Bob "hot rod" Rohr
HVAC Nut, Thanks I never heard of First Company
EBERETT I will be contacting Magice Aire
Iron Man, Thank you sir
Hot Rod I am going back to the jobsite to see what will fit.
Thanks allRay Wohlfarth
Boiler Lessons0 -
aermec.us if you want really quiet0
- 120 Geothermal
