Looking for a small hydronic fan coil unit
RayWohlfarth
RayWohlfarth Member Posts: 1,987
I want to replace a small hydronic fan coil which is only 35" wide 9 3/8' deep, 25" high 200 CFM
I cannot find one less than 40" wide. The wall encasing this unit will not allow a wider unit. Its 110 volt
I would be eternally grateful for any suggestions.
Thank you in advance.
Ray
Ray Wohlfarth
Boiler Lessons
  • Harvey Ramer
    Harvey Ramer Member Posts: 2,289
    Did you look at the Aircell product from spacepac?
  • Dan Foley
    Dan Foley Member Posts: 1,268
    Try Magic-Aire
    HVACNUT Member Posts: 7,460
    edited September 2017
    Are you looking for a PTAC type, or just the coil? Did you try Aquecoil if just the coil?
  • RayWohlfarth
    Harvey Thanks They want a replacemet for the existing.
    Dan Foley thanks I will check it out
    HVAC nut it will use hot or chilled water and a fan
    I apperciate it all
    Ray Wohlfarth
    Boiler Lessons
    Did you try First Company?
    They have hydro air units for many applications.
    EBEBRATT-Ed Member Posts: 20,206
    as @Dan Foley said Magic Air is worth a try
  • Ironman
    Ironman Member Posts: 7,904
    Multi Aqua is another option to look at.
    Bob Boan
    hot_rod Member Posts: 27,487
    What about a kick space heater, they come in wall mount cabinet style.
  • RayWohlfarth
    HVAC Nut, Thanks I never heard of First Company
    EBERETT I will be contacting Magice Aire
    Iron Man, Thank you sir
    Hot Rod I am going back to the jobsite to see what will fit.
    Thanks all
    Ray Wohlfarth
    Boiler Lessons
  • Jim_161
    Jim_161 Member Posts: 8
    aermec.us if you want really quiet
  • RayWohlfarth
    Thanks Jim I will look into them
    Ray Wohlfarth
    Boiler Lessons
