Combustible gas detectors
ChrisJ
Member Posts: 15,767
Hi all,
Anyone have any experience with combustible gas detectors?
Can anyone recommend a good one? I see they make some that are built into CO detectors, but they get mixed reviews.
This is for natural gas.
I'd like something perhaps even good enough to wire into a system to shut the gas off if it detects something. But not something that will likely cause complaints over nothing.
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment
do you mean combustion kits, i have a bacarach works great, i can even change my own sensors every two years, now thats a feature i like alot instead of sending it out every two yrs"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
No, no.newagedawn said:do you mean combustion kits, i have a bacarach works great, i can even change my own sensors every two years, now thats a feature i like alot instead of sending it out every two yrs
I mean one that can be installed in a space, similar to a smoke detector.
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
I've installed a number of Honeywell Analytics combustible gas detectors. They make models both with and without communications, but I think they all have a pair of relays in 'em. Certain models will take a slave sensor that will give you roughly twice the coverage for (I'm assuming!) less than twice the cost. Kele has a line, and lately we've been installing Armstrong sensors, no doubt as a value-engineered item, but IDR if they have a combustible gas option.2
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
