Combustible gas detectors
ChrisJ
Member Posts: 17,068
Hi all,
Anyone have any experience with combustible gas detectors?
Can anyone recommend a good one? I see they make some that are built into CO detectors, but they get mixed reviews.
This is for natural gas.
I'd like something perhaps even good enough to wire into a system to shut the gas off if it detects something. But not something that will likely cause complaints over nothing.
do you mean combustion kits, i have a bacarach works great, i can even change my own sensors every two years, now thats a feature i like alot instead of sending it out every two yrs"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
No, no.newagedawn said:do you mean combustion kits, i have a bacarach works great, i can even change my own sensors every two years, now thats a feature i like alot instead of sending it out every two yrs
I mean one that can be installed in a space, similar to a smoke detector.
I've installed a number of Honeywell Analytics combustible gas detectors. They make models both with and without communications, but I think they all have a pair of relays in 'em. Certain models will take a slave sensor that will give you roughly twice the coverage for (I'm assuming!) less than twice the cost. Kele has a line, and lately we've been installing Armstrong sensors, no doubt as a value-engineered item, but IDR if they have a combustible gas option.2
- 114 Geothermal
