rusty "new" gas boiler?
yuli_osu
Member Posts: 3
in Gas Heating
Hi, my HVAC contractor is installing a new Weil-Mclain GV90+4 natural gas boiler in my house. But when the box was opened, the back of the boiler looks very rusty. Please see attached photos for the rusty part and the CP number in the back.
Is this kind of rusty condition normal for a new unit?
I have read online that rusty exchange is the worst enemy of a gas boiler.
I am a new customer of Weil-Mclain gas boiler. Thank you in advance for your help!
To note: I'm not a pro but have had to deal with a boiler by WM. Section that we got after one was being replaced was also a bit more on the rusty side, but it was all surface rust and nothing structural. As long as integrity is fine, surface rust won't hurt it.
Before this gets any farther along with the install, if it were me, I would call the distributor to come out and see this. Better safe than sorry. What does your installer say? Some rust is normal on these as they may sit around for a while and they are cast iron. Although there usually is some oil left over from casting, rusting should not be extensive. This to me looks like excessive rusting, and maybe even bad casting. I would not believe the casting is bad as there is quality control (hopefully) on these before they go out, but from the photo it also looks like there is a large crack along the top edge. Maybe it's the photo. Get the distributor to come out and take a look. Crack is a no-no.1 -
Never been a big fan of those boilers plus I thought they stopped making them. Call WM and give them the CP number and see when it was made.0
Many thanks, MilanD & kcopp. I did get the distributor to come out and he said this was due to water pressure testing at the factory, which leaves the surface rusty. Many thanks for your help!0
Many thanks, unclejohn, this is very useful!0
Pretty normal. Wipe it down with an oily rag.New England SteamWorks
newenglandsteamworks.com-1 -
Oily rag could cause orders, jmoNew England SteamWorks said:Pretty normal. Wipe it down with an oily rag.
They'll burn off, nothing to worry about.0
A contractor may understand it will burn off, but mommy with new baby will scream,and as well she should...Danny Scully said:They'll burn off, nothing to worry about.
> That's what pacifiers are for. As for the baby, close the door to the nursery and crank up the Metallica.0 -
Yup kinda agree....0
Ah.HVACNUT said:
It's been my experience mom's least worries are the new boiler when it comes to smell.https://youtu.be/I1LI7ndOcGU
I think we've gone on a small tangent.
@yuli_osu I wouldn't be concerned about the surface rust.
In a few years that entire block is going to be nothing but rust, it's just how cast iron is. The good news is, it won't effect it's life or performance.
Cheers.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
