Burnham Independence vs. Crown Bermuda
Morris_Wanchuk
Member Posts: 2
I am in Massachusetts and converting from Oil to Natural Gas. National grid is offering discount pricing on Burnham Independence boilers purchased through them. I have been getting quotes from local contractors and directing them to this information. I had one contractor say he could get a Crown Bermuda Steam boiler for around the same price as the discounted Burnham Independence. He said in his opinion that Crown was a better product the Burnham. I have not seen much about Crown Boilers online and wanted get get some feedback. Thanks!
Well,
First, I'd never hire the gas company to put a boiler in. So that takes the discounted Burnham Independence off the list. That's my opinion anyway and that plus a few dollars will buy a cup of coffee.
That said, the most important part is the installation. The piping around the boiler etc.
The brand of boiler doesn't mean much, if anything to be honest.
Before any boiler is ordered, someone needs to go around and do a radiator survey. Personally, I'd also recommend a basic heatloss be done as well and I feel piping losses should also be estimated.
After that's done, the proper size boiler can be selected.
Some guys are going to argue about the heatloss and that's fine. Personally, I feel it helps.
At a bare minimum a radiator survey must be done.
Once the proper size boiler is piped correctly all leaks must be fixed to minimize water consumption. I would recommend new main vents and all new quality radiator vents if applicable.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
To clarify the Burnham boiler is bought from the gas company by the plumber at a discount and installed by the plumber. I have had a few quotes with all the boilers the sized the same based on a radiator survey. Just wondering thoughts on crown boilers.0
personally, I haven't herd anything bad about Crown0
Basically the same boiler, just trimmed out differently.
You need to heed the warning about the installer. You want a "steam fitter" not just an ordinary plumber. Steam is a lost art and very few plumbers or HVAC guys know anything about it. The wrong installer can really mess it up bad.
Try the contractor locator above.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.2 -
Best option find a contractor on the find a contractor list on this forum. If none found ask for what they recomend.
both are junk
"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0 -
Do you have a better option for a steamer?newagedawn said:both are junk
