Weil McLain boiler rusted out after 3 years, distributor replaced
kseering
Member Posts: 4
Please see current Post with Pictures. I am not a drive by. I went on Vacation and it took time to get all the info. This is freaking me out. We cant afford a new boiler every couple of years. Is there an alternative to weil McLain ??
Need more information. What type of system, which boiler and as always pictures of the install would help a lot. I can't imagine a cast iron boiler rotting out in 5 months. I can't think of any way that would be possible short of a salt corrosion tank.1
What's kept in the basement?
Any chlorine products? Pool treatment products?
The distributor obviously doesn't have a clue.
Is this a steam or hot-water system?All Steamed Up, Inc.
Consulting0 -
I can hardly imagine an environment, short of a factory that produces industrial oxidizers or something, that could rot out a cast boiler within a single season. Hopefully this guy posts back!
What is actually corroding, the HX or the jacket? What are the symptoms that you are getting?0 -
Maybe constant heavy water make up plus high humidity environment close to the ocean, next to a desalination plant, above a leaky salt water aquarium...0
Well if he really cares he will come back and post....Mabe just rocking someone's boat0
@j a said, "Well if he really cares he will come back and post....Mabe just rocking someone's boat"
Couldn't agree more. Think we are wasting time on this one sounds fishy2 -
Yes Ed I smelled fish thing as well..EBEBRATT-Ed said:@j a said, "Well if he really cares he will come back and post....Mabe just rocking someone's boat"
Couldn't agree more. Think we are wasting time on this one sounds fishy0 -
Yes, post some pics and any other info.
Wondering, is it a large boiler that had to be split to get it to boiler room?
The CI is actually disintegrating, or is it leaking between the sections?
Well water, or city water?0 -
its the new china cast, get ready for more,lol"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
Really sad for the hard working customers....the end user and end installer suffer the mostnewagedawn said:its the new china cast, get ready for more,lol
3 -
Doesn't WM cast their sections at a foundry in MichiganCity, IN?newagedawn said:its the new china cast, get ready for more,lol
I've never had a WM that my company has installed fail in less than 20 years that we are also contracted to annually maintain. Most failures of others' installs I have noticed are mostly due to excessive makeup water usage due to leaking wet returns or excessive steam loss at radiator valves. Water usage data for steam boilers needs to be maintained. Personally I'm pretty satisfied with WM quality.2 -
I've never had a WM that my company has installed fail in less than 20 years that we are also contracted to annually maintain. Most failures of others' installs I have noticed are mostly due to excessive makeup water usage due to leaking wet returns or excessive steam loss at radiator valves. Water usage data for steam boilers needs to be maintained. Personally I'm pretty satisfied with WM quality.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
