Weil McLain boiler rusted out after 3 years, distributor replaced
kseering
kseering Member Posts: 4
edited September 2017 in Gas Heating
Please see current Post with Pictures. I am not a drive by. I went on Vacation and it took time to get all the info. This is freaking me out. We cant afford a new boiler every couple of years. Is there an alternative to weil McLain ??
  • KC_Jones
    KC_Jones Member Posts: 5,902
    Need more information. What type of system, which boiler and as always pictures of the install would help a lot. I can't imagine a cast iron boiler rotting out in 5 months. I can't think of any way that would be possible short of a salt corrosion tank.
    2014 Weil Mclain EG-40
    kcopp
  • ChrisJ
    ChrisJ Member Posts: 17,048
    What's kept in the basement?
    Any chlorine products? Pool treatment products?
    Steamhead Member Posts: 18,183
    The distributor obviously doesn't have a clue.
    Is this a steam or hot-water system?
    Consulting
  • j a_2
    j a_2 Member Posts: 1,804
    Best thing is to post a picture, you say sealed off from everything in its own room. Honestly, can't give a good answer till more information is given...
    kcoppCanuckerZman
  • Zman
    Zman Member Posts: 7,611
    @kseering
    Need lots more info. Is it steam or hot water? What are the temp settings? What type of vent/chimney? Where does the combustion air come from?
    Don't be a one post wonder...
    Albert Einstein
  • j a_2
    Zman said:
    @kseering
    Agree
  • zmcgarvey
    zmcgarvey Member Posts: 20
    I can hardly imagine an environment, short of a factory that produces industrial oxidizers or something, that could rot out a cast boiler within a single season. Hopefully this guy posts back!
    What is actually corroding, the HX or the jacket? What are the symptoms that you are getting?
  • kcopp
    kcopp Member Posts: 4,611
    just a drive by poster....
    j a_2RomanGK_26986764589
  • MilanD
    MilanD Member Posts: 1,162
    Maybe constant heavy water make up plus high humidity environment close to the ocean, next to a desalination plant, above a leaky salt water aquarium...
  • j a_2
    Well if he really cares he will come back and post....Mabe just rocking someone's boat
    EBEBRATT-Ed Member Posts: 19,420
    @j a said, "Well if he really cares he will come back and post....Mabe just rocking someone's boat"
    Couldn't agree more. Think we are wasting time on this one sounds fishy
  • j a_2
    Yes Ed I smelled fish thing as well..
  • Zman
    I messaged the OP. He will post more info shortly.
    Albert Einstein
    Canuckerkcopp
    HVACNUT Member Posts: 7,191
    edited August 2017
    Yes, post some pics and any other info.
    Wondering, is it a large boiler that had to be split to get it to boiler room?
    The CI is actually disintegrating, or is it leaking between the sections?
    Well water, or city water?
  • j a_2
    It's all a mystery so far
  • newagedawn
    newagedawn Member Posts: 586
    its the new china cast, get ready for more,lol
    "The bitter taste of a poor install lasts far longer than the JOY of the lowest price"
  • j a_2
    Really sad for the hard working customers....the end user and end installer suffer the most
    newagedawnMilanDRomanGK_26986764589
  • Abracadabra
    Doesn't WM cast their sections at a foundry in MichiganCity, IN?
    I've never had a WM that my company has installed fail in less than 20 years that we are also contracted to annually maintain. Most failures of others' installs I have noticed are mostly due to excessive makeup water usage due to leaking wet returns or excessive steam loss at radiator valves. Water usage data for steam boilers needs to be maintained. Personally I'm pretty satisfied with WM quality.
    RomanGK_26986764589j a_2
  • j a_2
    I agree and can say the same for Burnham and Peerless
