Oil furnace problem
islas0
islas0 Member Posts: 1
I was trying to restart my oil furnance and it wasn't restarting with the reset button, so I pulled this plug on the high speed flame retention and when it came out it sparked and then the power went out in my house. How can I fix this problem?
  • JUGHNE
    JUGHNE Member Posts: 11,549
    All the power in the entire house went out because of one action??
  • ratio
    ratio Member Posts: 4,238
    Might be time to call a pro. There's a lot of different ways to hurt yourself or start a fire.
    HVACNUT Member Posts: 7,452
    That summary was a little vague, but if sparks were involved, you need to call a pro. Set it up for tomorrow or you'll likely pay overtime rates today.
    You lost power to the whole house?
    It should have just tripped the breaker for the boiler only.
    JUGHNE
    Jamie Hall Member Posts: 27,376
    As has been said -- you need a pro for the burner. You also may need an electrician, if the whole house tripped. In fact, if it did, you do.
    newagedawn
