sealer needed for plastic drain pan
zepfan
Member Posts: 444
looking for recommendations on a temporary sealer for a plastic drain pan that is in a five ton Trane air handler model# 4tec3f60, installed in the upright position. The pan has already been replaced about five years ago, and now it has cracked again. I have used in the past with not good results at all the Nucalgon product cal spray. i was posting to see if anyone had good luck with something else.I plan on replacing the pan, but was looking for something to get the customer through until when the part arrives Thanks to all.
I've had good luck with diversatech aluminum silicone adhering to plastic and metal.0
I have used duct sealer mastic, the type you paint on with brush or foam sponge. Just a long dry time involved. I used heat gun to help cure. It claims to be waterproof and seemed to be so.0
Used this with 2-3 year success rate.
https://www.geocelusa.com/product/geocel-4500-roof-bonding-sealant/-1 -
- 167 Indoor-Air Quality
