BTU rating for a cast iron convector in 48"x24'' cabinet need advise/ help please
Johnyguy
Member Posts: 6
Hello
I have a living room and i have a old steell convector 30 inch long, the space is 280 SF 13'x22' i purchased a 47 inch by 6 inch two tier cast iron convector based on the recommendation for the room it is a steam system in a building 1st floor APT the living room is next to kitchen on one side and bedroom on the other side i like to know if i got the right size convector ?? Some expert please let me know what you think? the cabinet is going into is 48 inch by 24 height goes under the window
THANK YOU!!
THANK YOU!!
I meant the cabinet is 48"x24"0
Can you make some sort of ballpark guesstimate of the total surface area -- fins (both sides) and pipe and all? If you can, then the BTU rating for it will simply be 240 times that surface area, in square feet... depending on how the cabinet is built, it might knock as much as 20 to 30 percent off that -- but that's a ballpark, too, and if there are sufficient openings (top and bottom) in the cabinet, it won't even be that much.Br. Jamie, osb
pictures..picturesgwgillplumbingandheating.com
HI thank you for the reply yes i know that the convector i am looking at it has a rating of 9600 BTU my question is is that enough for my the 280 SF living room the next size up is 11280 BTU would that be an overkill? is that true if the cabinet is 24" high i get better BTU than from a 20" high cabinet!Jamie Hall said:Can you make some sort of ballpark guesstimate of the total surface area -- fins (both sides) and pipe and all? If you can, then the BTU rating for it will simply be 240 times that surface area, in square feet... depending on how the cabinet is built, it might knock as much as 20 to 30 percent off that -- but that's a ballpark, too, and if there are sufficient openings (top and bottom) in the cabinet, it won't even be that much.
Thanks!!0 -
This is it
And the cabinet is 24" tall just like on the picture0 -
They recomended me a 47" long one which has a rating of 9840 BTU
The next size is 55" with rating 11760 BTU whic one should i get i dont want to overheat the space but i want the rigth size for the room.0 -
please see pic above0
