Is your refrigerator safe?
http:/dailymail.co.uk/news/article-4634612/Video-shows-British-style-fridge-flames.html
This other article discusses the dangers of refrigerators with flammable refrigerants. I have one of these.
http:/acr-news.com/are-our-fridges-safe
Boiler Lessons
Ray, the article link doesn't work... can you repost?
http:/acr-news.com/are-our-fridges-safeTerry O0 -
Thanks, Ray. Here's the link, Terry - http://www.acr-news.com/are-our-fridges-safe?
President
HeatingHelp.com0 -
I don't know about yours, but mine are safe, yep.
Flammable refrigerant and all.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Try this link:
http://www.dailymail.co.uk/news/article-4634612/Video-shows-British-style-fridge-flames.htmlAll Steamed Up, Inc.
Consulting0 -
No fire sprinkler system in a building that tall?0
No sprinklers in the building Thats kinda scary. They had a bad fire in hotel in Hawaii over the weekend they had no sprinklers either
Ray Wohlfarth
Boiler Lessons0 -
So essentially,Gordy said:Sprinklers Was not code when built in Hawaii.
Most of the reason for the quick spread of the uk fire was due to the assembly of a recent exterior renovation. The skin had no fire blocking, and acted like a chimney.
Refrigerators should have a metal shell, at least to enclose the spray foam. And buildings need fire blocking, something we've known for what, 100 years or more?
Sprinklers are expensive, until you need them.
2 -
Yes you are correct Chris. However would you go to the extra expense to put a sprinkler system in your home if it was not code?
Fire blocking was actually not even dealt with until the 60's let alone code.
The cladding that was installed on several high rises in question now in the U.K.
https://www.thesun.co.uk/wp-content/uploads/2017/06/dk-composite-inferno-graphic.jpg?strip=all&w=536&quality=1000 -
Just because something isn't, or wasn't code doesn't mean it wasn't done.Gordy said:Yes you are correct Chris. However would you go to the extra expense to put a sprinkler system in your home if it was not code?
Would I install a sprinkler system in my house if I was building from scratch? Good chance, yeah. I would also like steel framing.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Good conductor.0
Fine, then!0
SIP.0
There would be a good chance you wouldn't insulate. Let alone install a sprinkler system. If it were not code. If it's coming out of your wallet.ChrisJ said:
Usually residential code follows commercial code requirements in slow succession.
Most mistake residential structural blocking reinforcement. AKA solid bridging in walls, and floors as fire stop in older residential dwellings. Although location details are similar it was not installed as fire blocking in its context.
We can all say it would be a good idea, and a prudent safety precaution. However the mighty investment dollar over rules the lack of such written, and enforced code authority.
Just so everyone is aware. Most sprinkler systems are designed to slow fire spread not extinguish it. The fire department does not even expect that much.
Residential sprinklers often extinguish the fire before it spreads, like over a sleeping smoker on a couch
A very high success rate with residential systems and the Uponor pex systems make it fairly affordable.
I installed a single head in the room with my wood boiler, on the potable water system.
The trick with resi systems is supplying enough gpm. The basic code we worked with required proving two heads flowing.
Homes in the trees required 4 head flowing outside, that takes a lot of flow and pipe size. Plus a large meter set, gets $$.
We installed copper systems, then CPVC, if I were still in that business, probably pex would be the product I'd look at.
http://www.nfpa.org/public-education/by-topic/fire-and-life-safety-equipment/home-fire-sprinklersBob "hot rod" Rohr
Most multi sprinkler head layouts are designed to cover escape routes from sleeping areas to safely exit the dwelling as a minimum.0
I'll never forget witnessing how quickly a home can become fully engulfed on a windy day. Especially a drywall ,fibreglass cavity insulation, exterior foam board, vinyl siding wall detail. 15 min. Tops.
Vehicle in garage started fire.0 -
It is rumored that in the future fire dept will be discouraged from doing "interior" attacks. That is 2 fighters geared up with air packs and 1 1/2" to 2" hose with pressure near 100PSI. 2 others outside at the door ready to go in if needed.
The "new" method may be to attack thru windows and doors with water stream. Could lead to a total gut burn out of structure.
Main reason being (IMO) is the materials in a newer home.
Manufactured floor joists held together with glue/plywood/chip board sheeted with chip board burn thru quickly compared to 2 x 10 lumber covered with plywood or 3/4" lumber.
Roof trusses held together with glue and press plates.
All amounting to kindling/twigs compared to solid lumber components.
All house furnishings, rugs, drapes, furniture, clothes, kids toys etc are some form of poly/plastic, somewhat like gas burning.
It is now common to climb onto the roofs and saw a hole to vent the heat/smoke out, that will probably be limited because of roof structures becoming more susceptible to burn thru caused by the fuel contained inside the house.
So smoke detectors are stressed to be installed and then get out of the house quickly.
Sprinklers could prevent many small fires from going bigger. IMO1 -
I'm assuming that you have a backflow preventer connected? I've never installed a sprinkler system and I couldn't tell you the requirements but I have seen the water that comes out when a forklift rips one of the heads off. Wouldn't want to be drinking that.You can have it good, fast or cheap. Pick two0 -
I wonder if it would be feasible to pump a house full of an inert gas to displace the oxygen and then attack flames from the outside with water? Of course all occupant would have to be vacated first.0
Fire dept around here won't go into a home known to have TJI, or BCI floor joists unless there is a need for occupant rescue. No meat In them just plywood, wood chips and glue.
I have done super air sealing for a server room at a local college. They converted from a dry system to inert gas as the extinguishing agent. The server room had to basically hold an X concentration of the inert gas for 10 min. Doesn't sound like a long time, but it is.
The server room was approximately 50x50. With 12' grid ceiling. All tiles were Gasketed. It was a pain, but it passed on first test. The gentleman who performed the test for the suppression system said he never had one pass on the first test.
The server room also had a drop floor for cooling, and running cables. Pic attatched.
Depending on the gas, and intensity of the fire. It would be near impossible to have the concentrations needed to use even in a tight envelope.
The commercial grade sprinkler systems I have seen were typically piped in black steel pipe. Definitely back flow devices installed.
The water in them looks like it came out of the bottom of a steamer.
They have some testing flush valves going to mech room floor drains or mostly here they go outside if possible.
The side of one building has the obvious staining from testing/flushing. In that case they could have piped it lower than the 4' height to avoid that.......but some sprinkler installers do what they want. That particular installer crew considered themselves the only true trade on the job.-1 -
- 110 Chimneys & Flues
- 978 Plumbing
- 387 Solar
- 17 Recall Announcements
