Viesmann Vitorond Recommendation???
pvansavage
Member Posts: 2
in Oil Heating
Need to replace my oil burner, and have a bid for a Viesmann Vitoron 100 - a name I'm having difficulty getting layman's information on. Need to know (based on what I've researched I need) if this is a sealed combustion unit, cold start, with a thermal purge feature?
Also want to know if the Outdoor temp reset is standard?
Is a Garber spin-on filter a good thing?
Lastly, what's a tankless coil, and why do I want to avoid that? Is that the hot water heater? Is a Heat-Flo 40 water heater adequate for a family with three teens?
Is this a good, reliable, easily repaired (if necessary) unit?
What else should I be asking for?
Not sealed combustion unless direct vent, although it could be added. It should be wired cold start, outdoor reset is optional, the standard control is a Hydrostat which uses a form of thermal purge although nothing like what I believe you're comparing it to. Viessmann make a great product.To learn more about this professional, click here to visit their ad in Find A Contractor.1 -
Thank you! Very helpful. Now just need to get my head around coupling it with a HR-40... More cost efficient to operate than electric?0
Depends on your electric rates and what you pay for oil. 1 gallon of oil= 139,000 BTU. 1 Kw= 3421 BTU. Minus the losses with oil.To learn more about this professional, click here to visit their ad in Find A Contractor.0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 995 Plumbing
- 391 Solar
- 55 Water Quality
