Repair or replace
petermcd
petermcd Member Posts: 1
I have a 18 year old home in Maine with an oil fired furnace and a power vent. The power vent is the original and is getting loud. Do I spend money to replace vent or do
I look for a more efficient furnace? The furnace is very dependable, which is important to us as we decamp to Florida for 6 months in the winter. I have read about direct vent oil furnace, we do currently have a tankless hot water system. Propane for the last 24 months is more expensive than oil.
Thanks in advance for any thoughts
    Jamie Hall Member Posts: 26,716
    The real question is -- why is the power vent getting loud? Bad bearings? Unbalanced? Perhaps a slight leak in the piping? Figure that out first. My own thought would be to replace the vent, if need be. A lot easier. And cheaper...
    petermcd
    EBEBRATT-Ed Member Posts: 19,336
    If it's been working for 18 years and it's in decent shape just change the vent.
    petermcd
  • STEVEusaPA
    Power vents are usually overlooked with annual maintenance. Sometimes just the blower wheel needs a little attention-clean/lube.
    Also if your not around all winter I would recommend some freeze protection/alarm so you immediately know if their is trouble. Lining up service as soon as their is trouble could prevent a disaster.
    petermcd
