Jerry rig broken AC pan drain line holder
Well, I'd surely get rid of that mold. You might consider spraying some bleach solution -- around 5 percent perhaps? -- on the coils, too, then rinsing then,
I've not found super glue to be too helpful on plastic bits but there's no harm to trying. The tape will probably hold -- well enough, anyway.Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England-1 -
Use super glue (preferably the viscous kind) to immobilize it and when that dries use clear RTV on the outside. You want the clear RTV with the ascetic acid because it holds onto almost anything; white RTV isn't nearly as good for something like this.
3PSI gauge-1 -
Hello, There are some epoxies made for plastic. They form a thin paste that might work nicely here if you clean and sand the mating surfaces. Here's one: http://www.midlandhardware.com/163486.html?utm_source=bing&utm_medium=cpc&utm_campaign=**LP - Shop - Adhesives&utm_term=4575686358611614&utm_content=163486 | J-B Plastic Weld Epoxy 25 ML 50132 | $4.02
Yours, Larry-1 -
Great suggestions thanks. I also heard of this powdered epoxy for drain pans, but having to mix it up would make it a bit cumbersome I think: https://www.walmart.com/ip/Pan-Patch-Drain-Pan-Sealant/37891972 Also I guess Super Glue is better than Gorilla Glue, which I happen to have. Someone also suggested using the other drain port after raising the height of the damaged area, but then I'd have to jerry rig some new plastic drainage piping to match up to the rest of it.0
There is already an second larger drain pan--perhaps not visible in photos--underneath the handler that has its own drain line that joins up with the primary drain line but that one has no trap and unfortunately whoever installed this years ago has the drain line threading right into the top of the plumbing stack: sewer gases.
Also I am concerned that the mold is in the path of the air going out through the handler to the trunk, the feeds, then metal ducts to the room registers. Should I have all this checked and/or cleaned before I use the AC again? Seems like AC pans will always be wet as they drain out--how is mold prevented?0 -
Clean the entire thing well with very and see how it goes.
In the winter when it dries out completely you could give it another cleaning.
A UV light is an option to killing growing things that love evaporators and pans.
As an example :
http://www.supplyhouse.com/Trion-UV360-1-ComfortBreeze-High-Efficiency-High-Output-UV-C-Lamp-Air-Cleaner-System
Here's a brochure on it.
http://s3.supplyhouse.com/product_files/Trion-UV360-1-Product-Overview.pdf
-1 -
@ChrisJ Thanks! I cleaned off the mold today but noticed that part of the problem--undiagnosed on various service calls through the years––is that the pitch of the unit is not quite right--it pitches down on one side awa from the drain port, so a bit of water will always be in there. Since the unit is sitting on two two-by-fours in the outer pan, I might be able to shim it up slightly. You left out a word in your first sentence. 'clean the entire thing well with very __________?0
I was going to say diluted mixture of water and chlorine.David107 said:@ChrisJ Thanks! I cleaned off the mold today but noticed that part of the problem--undiagnosed on various service calls through the years––is that the pitch of the unit is not quite right--it pitches down on one side awa from the drain port, so a bit of water will always be in there. Since the unit is sitting on two two-by-fours in the outer pan, I might be able to shim it up slightly. You left out a word in your first sentence. 'clean the entire thing well with very __________?
The problem is, I still don't know how safe even weak chlorine is to use near or on an evaporator.
This post talks about putting a swimming pool chlorine tablet in the evaporator pan and also using bleach to flush the evaporator tube.
https://www.thisoldhouse.com/ideas/air-conditioners-really-are-getting-better0 -
If you can hold off another 3-5 years I would
Saw a guy on youtube put crazy glue on a plastic crack then put baking soda over it while it cured, made it solid like a rock. Talks a bit on the intro but results are good.
https://www.youtube.com/watch?v=alyzGrgL6So 0 -
http://www.homedepot.com/p/J-B-Weld-Waterweld-8277/202528473
I've used this and similar products. JB water weld. I had a hot tub drain leaking once that couldn't be reached but with one hand. A huge project to cut framing to replace a trap and some pvc. I made a snake out of this stuff and wrapped it around the pipe. Then just squeezed it and smashed it all around pipe flat. It gets hard as rock. Lived there 7 years longer and it never leaked. Plus you can sand it if you need too. I'd put that stuff all on the outside because you can build it out more. Even wrap it up and over the drain tube because once it gets hard it will be like an added brace. Then on the inside seam just put a little silicone to keep the water out of the seem.
I keep a stick of this in my car as emergency item. Pro tip: mix it good but use gloves. You are basically kneading it into your hands if you mix it enough. Didn't have the easiest time getting it off my hands on my first use of it. haha
*edit. I might even drill a few holes like 3/8" on the edges up a little higher where water probably doesn't go. That way you can jam it through the holes and then flatten the otherside out like stove bolt. Probably be stronger then original.-1 -
FWIF, I used this thing* on the pan crack, exact spot like yours on the drain, except not all the way broken off, plus a horizontal crack off on the flat pan surface, under the coil. It kept pan from leaking a few years. When it started again, cleaned and redid again.
* https://www.geocelusa.com/product/geocel-4500-roof-bonding-sealant/
* any good roofing supply company will have these in stock.-1
- 15.8K Strictly Steam
