Hit the wall wiring for thermostat
The yellow is for cooling, I assume you do not have air conditioning?
The black wire appears to be your common.
Blue is your fan (G), often a green wire.
Brown is your (W), often a white wire.
The letters are right on the control board of the furnace.
Curious, if you're renting, should you be messing with the thermostat?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Can you post a pic of the wiring diagram-probably on the board cover or the back of the furnace/blower door. If it doesn't tell us, can you also tell us the make/model of the furnace
"Electricity don't know no color." My Old Guy taught me that years and years ago. The colors are just there to make your job easier.
WRT your stat, the names of the terminals are what's important, line them up like to like on the furnace control board. C is the common (power return), R is the 24 volt hot (power), G is the fan call, W is the heat call, Y is (would be) the cool call. R & C provide the power to the thermostat, if you run on batteries you don't need the C. I don't recommend batteries. Much better to be powered from the furnace if possible.0 -
That's my confusion. I do have central air. But where's the yellow. Long term lease and I pay for electricity. I can always swap back.ChrisJ said:The yellow is for cooling, I assume you do not have air conditioning?
Curious, if you're renting, should you be messing with the thermostat?0 -
White red black blue?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I've changed thermostats before, but this is a mess. Once I can figure out what's going on...STEVEusaPA said:Can you post a pic of the wiring diagram-probably on the board cover or the back of the furnace/blower door. If it doesn't tell us, can you also tell us the make/model of the furnace
I've posted addition pics0 -
how many wires are there at the thermostat?Bob "hot rod" Rohr
Looks like a hack job of quick replacement for failed components.
Your AC yellow and common is tied (wirenuts) in between the Tstat and furnace control board terms. The AC lowvolt wiring might follow the line set which would help you ID the wires.
The Y wire does not have to connect to the furnace board, only from Tstat to AC unit.
If the Tstat wiring is simple to replace I would run 18-5 cable to the furnace.....and 18-2 cable for the AC spliced in an easy spot.
This makes the color ID simpler.0
- 50 Industry Classes
