Need advice
kitchenremodel
Member Posts: 3
Hi. We are in the middle of a kitchen remodel, and noticed the gas connector/line in the floor for our gas stove has a drip of dried paint in it. This gas line is turned off right now, of course, as the gas stove hasn't been installed yet. Contractor says it's not an issue and he'll scrape the paint out of the line before connecting. Does this sound right? Advice appreciated!
Gas connectors aren't expensive and are NOT allowed by code to be re-used.Bob Boan
Standard practice is to cap the ends of gas, plumbing pipes and ducts to keep debris out during the rough in work. I wouldn't lose sleep over a drop of dried paint. Is this a new or existing gas line? If new, it should have definitely been capped to prep for a pressure test to check for leaks, as per code.0
Good question. I believe it's the old gas line by the looks of it. They did move it slightly, so I will confirm in AM.0
Good to know, and makes sense. Also, I think I should clarify, it's the gas valve in the floor that some dried paint is on the inside. I think I said gas line, which maybe is the same thing. Either way assuming that should be capped?0
- 119 Chimneys & Flues
- 76 Pipe Deterioration
