Debate on terminology
13»
  • wasup23
    wasup23 Member Posts: 3
    Air conditioning is anything to change a property of the air, anytime someone heats/cools/humidifies/dehumidifies/changes pressure/adds/removes/or moves air they are air conditioning.
    Refrigeration is the act of moving heat energy.
    Furnace is something that heats up matter.
    Boiler is something that heats a fluid.
    There is no such thing as cold.
    The hardest part of your job is getting the panel doors back on.
    Don't ever ask someone a question that can be answered with a multimeter.
    ChrisJ
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,424
    I love the last statement. I lived that today
    cell # 413-841-6726
    Canucker
  • TrueDat
    TrueDat Member Posts: 8
    MikeL said:
    I was always scolded for using the phrase " hot water heater " to describe a residential water heater..........
    Rich_49Gordy
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,034
    Hmmm, I've met thousands of water heaters. Should it ever happen that I meet a hot water heater I shall certainly call it by it's correct name! o:)
    TrueDat
