In line check valve for whole House water filtration/softener?
LionA29
Member Posts: 255
Hi guys, I picked up this Matco-Norca Dual Check Back Flow Preventer Valve but wanted to know if there is anything better the Pros can recommend?
Reason is, when my sprinkler turns on, its pulls water from my softer/filter also. So I have to shut the bypass manual down to run the sprinkler.
Any recommendations will be appreciated!
Thanks
Thanks
The line to your sprinkler should be connected to the incoming water main before the water softener. If it is, and it still pulls water from the softener, where is that water coming from?
A backflow preventer should go on the sprinkler feed line, to prevent any possibility of water from the sprinkler system from getting into the domestic water. In some areas this is required by code. In many areas the dual check which you referenced is not regarded as adequate backflow prevention for such a connection, rather a reduced pressure zone backflow preventer is required. Check with your authority having jurisdiction on that.Br. Jamie, osb
@Jamie Hall You're Quite correct on the installation and it is coming from the softener because there is a counter feature on the clock.
I took a picture and did my best to label it for clarification, hope it helps.
Sprinkler has a double check backflow preventer on that line going out.0 -
I don't see how it is pulling from the softener, unless the softener is supplied from a different source or main?
Does the softener have a flow meter that you see spinning when the sprinklers run?Bob "hot rod" Rohr
Thank you! I don't quite see how that arrangement will pull water from the softener, but... if it does, that double check you mention can be put in between the sprinkler takeoff and the softener and should help. May lose some pressure through it, but it shouldn't be too bad...Br. Jamie, osb
Thank you @Jamie Hall . I notice the internals are all plastic, I was looking for something more robust( stainless and brass)0
Installed Dual check backflow preventer and all is well. Thanks everyone who contributed!0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 945 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
