Wiring a Viessman Vitotronic 200 in conjunction with an existing 12 zone Taco system
TheJarman
TheJarman Member Posts: 2
edited May 2017 in Thermostats and Controls
Greetings
I have just replaced a conventional oil fired boiler (that was controlled by an aquastat) with a new Viessmann Vitorond 100 and a Vitotronic 200 Control Unit.
Question is the aquastat on the old unit had T T inputs that were activated by the Taco relay firing the boiler on a demand for heat.
No such connection on the Vito 200 or the Pump Power Module.
The existing house has 9 Zones of radiant with mechanical mixing valves and 3 zones of hi cap baseboard with no mixing valves.
I do not want to redo the existing manifold and all of the circs along with the Taco relays....
How do I make everybody shake hands and play nice?
Also there is a boiler bypass with a circulator to inject supply water into the return header to keep the boiler from condensing. How do I control this circulator?
Thanks
  • Ironman
    Ironman Member Posts: 7,903
    The 200 will operate off of its reset curve. No TT connection is necessary; it's a smart control.
    Bob Boan
    ferrociousghandi
  • TheJarman
    so no connection of any kind between the boiler controls and the taco relays?
    Thank you for the input.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,529
    No need , the outdoor reset control will shut off the boiler when the outdoor temp rises to the set point ...
    ferrociousghandi
  • Big Ed_4
    Primary secondary piping .. There should be an connection in the control for the boiler circulator .. Size the circulator for was is recommended .
