Adding a Taco SR501 to a existing SR503
frozen13
Member Posts: 5
Have an existing furnace with 3 current zones, two heat zones, and a DHW tank zone all controlled by a Taco SR-503 and Hydrostat Model 3150. I am adding a heating zone in my basement and have a Taco SR-501 I would like to wire in but not positive on how it should be wired into the existing system.
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.-1 -
Ironman,
I assume I wire it like the second page shows as a master and then move the DHW pump to the SR-501 and the SR-503 becomes a slave my 3 zones of heating? I have attached an image as a
reference.0 -
Do you have a cast iron boiler or a mod/con?Bob Boan
It's a Buderus G115WS/4 which is cast iron.0
I will found out tonight, thank you.0
Nothing is connected to C1. I've attached some images also.0
- 15.8K Strictly Steam
