Buderus 2109 again...
kcopp
Member Posts: 4,615
From time to time I see a post here about needed a replacement for a HS2109 boiler control.
Now I have an issue w/ the one and only one if these I have ever installed.
I must say I am quite dissappointed has no direct replacement for this other than the 2107.
IF you use the 2107 do you need to use the outdoor reset feature?
Getting a sensor through to the outside on this building is a difficult undertaking and is not needed.
Thanks. kcopp
Thanks. kcopp
Thanks..
Faster cleaner change out.
Lot less to Rewire.
No purging the entire system....its a big complex system.
It will work without outdoor sensor to answer your question.0
Thanks much.0
Regardless, you need to change the well. If Hydrostat, use their well if you want LWCO protection.0
already has a LWCO0
