A wireless solution to a million problems...
This relay can be powered with any typical single or 3 phase voltages, and the relay can handle a 20 amp load.
Check it out, and if you know of another competing relay, by all means, speak up. I'm always interested in seeing something new.
http://www.functionaldevices.com/building-automation/display.php?model=RIBW24B-EN3
ME
Yeah, RIB has all sorts of unique relays, high current switching capability is nice.Mark Eatherton said:Most people in the HVAC business are familiar with RIB's from Functional Devices. What many people don't know is that they make a wireless sending/receiving/repeating relay that uses Enocean platform. I had a job recently where I needed to connect an operator on one manifold, to a thermostat serving another manifold. And no interface wiring (other than the usual 24 VAC and end switch circuitry) between the two manifolds to make it work. Hence, my need for a wireless relay.
ME
HBX has some clever wireless stuff also. WiFi snowmelt detectors is a great idea.
They were just about to market when I spoke to them at ASHRAE Chicago. Good to know!0
Rib have some very cool things. We used on a boiler project which allowed the boilers to speak to the Building EMSRay Wohlfarth
Boiler Lessons1
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
