Decisions decisions decisions, gas mod/con
Solid_Fuel_Man
Member Posts: 2,644
With recent talk about fire tube HX and all the potential for failure, my (I thought) final answer of a Weil Mclain ECO70 is being second guessed. I'd considered a Viessmann 100, but the turndowns are not that great, but the watertube HX is a proven design. I may even consider the 200 line.
The data, design load of 50,000 btu at 120 degree water. Considering buying my own propane tank(s) and have sold my oil boiler and tank. Have the summer to decide, this will be essentially backup to my wood fired system. However may be used entirely when I'm not able to burn wood, so that is really not relevant I guess.
Mod/cons are few and far between around here, mostly oil still. Both are locally available and supported as well as Bosch and Lochinvar.
I'm willing to do it right the first time, but lack the long term expirence and reliability to pull the trigger on anything yet. The aluminum HX scares me in the Bosch.
Taylor
Taylor
Stay away from the aluminum. Water quality requirements go to another level. KHN 55....7:1 TDR.0
I have seen very few fire tube failures. I believe most of them where a result of poor water quality. It turns out they make great dirt separators.
I was speaking with the Lochinvar rep the other day. They are rolling out a 10 to 1 firetube in the near future.
I have had an original Triangle Tube for 10 years. I think I have replaced one cracked sensor about 5 years ago otherwise flawless..."If you can't explain it simply, you don't understand it well enough"
Albert Einstein1 -
Lochinvar has the KHN085 that is a 10:1. I have put in 8 or 9 so far, And they are working out great. Plus the HTP is also 10:1 I believe.
Rick0 -
The word is that the firetube model will soon follow with 10 to 1rick in Alaska said:Lochinvar has the KHN085 that is a 10:1. I have put in 8 or 9 so far, And they are working out great. Plus the HTP is also 10:1 I believe.
Rick"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
No triangle tube distribution in my area. However, that isn't as much of a problem as a breakdown isn't the end of the world honestly.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
The KHN line is a 10:1 fire tube except the 55 which is 7:1 tdr.0
The Lochinvar firetube is very similar to the Triangle Tube. If it is well supported in your area, that would be my suggestion."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
The KHN/WHN 055 was on my short list. I was fairly certain the same HX wad used in the Weil Mclain ECO series. Either Korean (think Navian) or European. TT may now manufacture their own, but I thought some smaller ones were outsourced.
As a side note, the stripped down ECO is the direction I was leaning as I already have an elaborate control system I built to control my existing oil boiler. It seems Lochinvar doesn't make a stripped down mod/con for less $$$.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
Cadet however it's WT.0
Yeah, I remember seeing the Cadet, has a Gionanni it looks like. If the whole thing didn't look so cheesy...Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
- 109 Chimneys & Flues
- 975 Plumbing
- 386 Solar
- 17 Recall Announcements
