A diaphragm tank air side is water logged. What to do?
kami4444
kami4444 Member Posts: 33
a ) bleed the water from the tank
b) drain the water from the wank
c) bleed the air from the tank
which one would it be?
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,853
    Replace it... It has failed.
    ME
    Canucker
  • jumper
    jumper Member Posts: 2,267
    >>Replace it... It has failed.<<
    ditto. I prefer old fashioned.
    Jamie Hall Member Posts: 23,344
    And third. Think about it. If there is water on the air side of the diaphragm, how did it get there? Through a leak or tear in the diaphragm, that's how. Which means it's done.
