baseboard ID help
GW
GW Member Posts: 5,135
It's not petite, could it be Suntemp? I need to cut the baseboard and add two end caps
Gary Wilson
Wilson Services, Inc
Northampton, MA
gary@wilsonph.com
    hot_rod Member Posts: 26,542
    Does it have a hinged damper, that could help narrow down the brand. Looks a bit like early SlantFin, except for the ridge in the cover panel.
  • GW
    it sure looks hinged, the HO took the pic.
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
    Steamhead Member Posts: 18,185
    Not Slant/Fin. Their larger baseboard is MultiPak 80, here:
    http://www.slantfin.com/products/multi-pak-80/
    Not current-model Suntemp or Weil-McLain either, doesn't match what appears on their site.
    You might end up installing completely new baseboard there.
    Consulting
  • GW
    yes thanks, I just sent her some costs to install some petite. yet iot's about 1/2 shorter and will need someone to nail on some quarter round to cover the gap
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • CTOilHeat
    CTOilHeat Member Posts: 56
    Could be Sterling? Lots of that around. Torrco carries it.
  • kcopp
    kcopp Member Posts: 4,614
    edited April 2017
    Sure looks like Petite 7 to me.
    You would know for sure if you pulled the cover off and saw those funky insulators on the fin.
  • GW
    Modern Petite
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • GW
    Hah you may be right! I didn't even notice the tape wasn't set to bottom of the cap
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
