baseboard ID help
GW
Member Posts: 5,184
It's not petite, could it be Suntemp? I need to cut the baseboard and add two end caps
Does it have a hinged damper, that could help narrow down the brand. Looks a bit like early SlantFin, except for the ridge in the cover panel.Bob "hot rod" Rohr
Living the hydronic dream0 -
it sure looks hinged, the HO took the pic.0
Not Slant/Fin. Their larger baseboard is MultiPak 80, here:
http://www.slantfin.com/products/multi-pak-80/
Not current-model Suntemp or Weil-McLain either, doesn't match what appears on their site.
You might end up installing completely new baseboard there.All Steamed Up, Inc.
Consulting0 -
yes thanks, I just sent her some costs to install some petite. yet iot's about 1/2 shorter and will need someone to nail on some quarter round to cover the gap0
Could be Sterling? Lots of that around. Torrco carries it.0
Sure looks like Petite 7 to me.
You would know for sure if you pulled the cover off and saw those funky insulators on the fin.0 -
Hah you may be right! I didn't even notice the tape wasn't set to bottom of the cap0
- 119 Geothermal
- 394 Solar
