Define a "Flooded Boiler"
D. McLean
Member Posts: 20
Specifically, can a laid up boiler be called "flooded" if it's laid up "wet"-- full of water? Probably a trivial question, I know. Thanks in advance!
If it is a steam boiler and it is full, it is flooded. Doesn't matter if it was flooded intentionally as a matter of protecting it or if some feed failure or just ignorance caused it. Personally, I would suggest any water level above what you consider the normal water line to be is flooded. It's a matter of degree.2
My question was simply, "Do you refer to a laid-up boiler that is not laid-up dry, as 'wet', or 'flooded'". I think I already knew the answer, but wanted opinions.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
