Define a "Flooded Boiler"
D. McLean
D. McLean Member Posts: 20
Specifically, can a laid up boiler be called "flooded" if it's laid up "wet"-- full of water? Probably a trivial question, I know. Thanks in advance!
  • Fred
    Fred Member Posts: 8,542
    If it is a steam boiler and it is full, it is flooded. Doesn't matter if it was flooded intentionally as a matter of protecting it or if some feed failure or just ignorance caused it. Personally, I would suggest any water level above what you consider the normal water line to be is flooded. It's a matter of degree.
    D. McLeannewagedawn
  • ChrisJ
    ChrisJ Member Posts: 16,838
    If a boiler is in a basement that floods, is that considered a flooded boiler?
    D. McLeannewagedawn
  • newagedawn
    newagedawn Member Posts: 586
    a flooded steam boiler ,lol, is when you can"t see the water line and you have to drain some buckets of water for the burner to fire
    "The bitter taste of a poor install lasts far longer than the JOY of the lowest price"
    D. McLean
  • Fred
    edited April 2017
    No, That's considered a Flooded Basement. Contents of that basement are secondary to what is flooded.
    D. McLean
    Jamie Hall Member Posts: 26,164
    Flooded is flooded, as noted above! However, the real question is how did it get flooded, and why? Things like insurance and so on, you know...
    D. McLean
  • D. McLean
    My question was simply, "Do you refer to a laid-up boiler that is not laid-up dry, as 'wet', or 'flooded'". I think I already knew the answer, but wanted opinions.
  • ChrisJ
    I think I'd call it flooded.
    It's flooded for a reason, but certainly cannot be operated until it's unflooded.
    D. McLean
