pump curve
RJ_4
Member Posts: 484
Asking for help to find a B&G pump curve , could not find it on their website.
B&G 1510 series BF 5.50 125AC
S/N CS9637-01 J40
GPM 33
FT 30
1 HP
1600 rpm ( this seemed a strange RPM )
Thanks RJ
S/N CS9637-01 J40
GPM 33
FT 30
1 HP
Thanks RJ
Would you mind posting what application this pump is being used on, and what problem you are wanting to solve?
It could be the speed is for 50 HZ current. Typically the same motor @ 60 HZ will have a higher speed; 1750 RPM.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0 -
It is at our union training center lab, I just began instructing there, Using it for demonstration, dead heading pump etc to find impeller size. previous instructor no longer around, don't no where pump came from Canadian ?
Not Canadian -- they're 60 hz too. That is an odd rpm, though. Do you have a way to check the actual running rpm?Br. Jamie, osb
Very good chance you could use this to check the RPM.
https://www.amazon.com/Briggs-Stratton-19200-Tachometer/dp/B0044AV5VK
I have one and it works on most things, as long as there aren't multiple shafts spinning. I've even used it on my drill press motor.
As you turn it, a stiff wire extends out the side. As it gets longer and longer, it'll hit a point where it starts oscillating, a lot. It's a very narrow spot and you can usually get extremely close to the rpm something is running.
has the motor been switched before?Bob "hot rod" Rohr
Not sure about anything appears the pump was donated to the J.A.T.C by someone, current instructors don't know where it came from. Update, just heard back from B&G Rep. the serial card was found It was registered as a 1800 rpm 1 hp 11/4 pump.
Thanks to all, I can always count on the wall for help.There was an error rendering this rich post.
- 87.1K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 996 Plumbing
- 391 Solar
- 55 Water Quality
